[gdal-dev] "ESRI Shapefile" Driver Not Found
Kyle Shannon kyle at pobox.com
Tue Jul 29 13:21:35 PDT 2014
On Tue, Jul 29, 2014 at 1:46 PM, Michael Aschenbeck
<m.g.aschenbeck at gmail.com> wrote:
> Hello,
> I'm having trouble creating a shapefile.  My problems are isolated to the
> following c++ block:
>     const char *pszDriverName = "ESRI Shapefile";
>     GDALDriver *poDriver;
>     GDALAllRegister();
>     poDriver = GetGDALDriverManager()->GetDriverByName(pszDriverName );
>     if( poDriver == NULL )
>         printf( "%s driver not available.\n", pszDriverName );
>         exit( 1 );
> which enters the conditional since it cannot find the "ESRI Shapefile"
> driver.
> The funny thing is that this driver loads no problem with my Python
> bindings.  Does anyone have any advice to help me out?
> Thanks,
> Mike
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Michael,
What version of GDAL are you using?  2.0+ has a unified driver
manager, but in previous versions the vector drivers (such as ESRI
Shapefile) were OGR drivers.  The older documentation can be found
here:
http://gdal.org/1.11/index.html
OGR docs:
http://gdal.org/1.11/ogr/index.html
OGR tutorial:
http://gdal.org/1.11/ogr/ogr_apitut.html
The documentation at gdal.org represents the development version and
if you are using the that version(2.0), AFAIK your code would work
fine.
Kyle
