[gdal-dev] AOI, Signature and Fourier Transform files' access?
Ivan Lucena lucena_ivan at hotmail.com
Wed Jun 4 08:01:33 PDT 2014
Hi Ramesh,
Are those files real raster images or auxiliary information, companion of .img files? Can you point to a website that describe those files?
There is nothing on [http://www.gdal.org/frmt_hfa.html] that says the HFA driver reads it.
Assuming that those are auxiliary information, would you like GDAL to convert the information on the signature/fourier file to another GDAL format that also supports it (if there one) or would you like to write your own application to deal with that information?
Best regards,
Ivan
Date: Fri, 11 Apr 2014 14:32:49 +0530
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] AOI, Signature and Fourier Transform files' access?
Dear all,Good Morning!
Is it possible to read/write ERDAS AOI, Signature (.sig) and Fast Fourier Transform image data from GDAL? If so, can anyone kindly teach me how to.
With many thanks,
Yours sincerely, B. Ramesh
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140604/e6a02d23/attachment.html>
