[gdal-dev] ogr2ogr and RFC41
Martin Landa landa.martin at gmail.com
Wed Jun 11 14:49:55 PDT 2014
2014-06-11 23:45 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> source geometry fields, you can write a SQL clause " SELECT geomfield1,
> geomfield2, other_attr FROM your_layer"
yes, but it's not really user-friendly (when more attributes are
listed). Probably `--geomfield` could be also used to select geometry
column when destination data source doesn't support RFC-41, what do
you think?
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
