[gdal-dev] ogr2ogr and RFC41
    Even Rouault
    even.rouault at mines-paris.org
    Wed Jun 11 14:54:33 PDT 2014
Le mercredi 11 juin 2014 23:49:55, Martin Landa a écrit :
> 2014-06-11 23:45 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> > source geometry fields, you can write a SQL clause " SELECT geomfield1,
> > geomfield2, other_attr FROM your_layer"
> yes, but it's not really user-friendly (when more attributes are
> listed). Probably `--geomfield` could be also used to select geometry
> column when destination data source doesn't support RFC-41, what do
> you think?
Actually, I see that I had upgraded the logic of the -select option to be able
to specify geomtry field(s) also.
> Martin
Geospatial professional services
http://even.rouault.free.fr/services.html
