[gdal-dev] ArcGIS RestAPI JSON Polygons
Jeremy Palmer JPalmer at linz.govt.nz
Mon Jun 23 10:46:40 PDT 2014
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#//02r3000000n1000000
> Can you?
> There is no geometry of multipolygon specified.
> AFAIU, for multipolygon ESRI REST produces a hybrid: a Polygon that
> contains detached rings
> (or rings not in other rings, so they are not holes) and that is
> interpreted as multipolygon.
> Fun.
The definition says polygons can have any number of rings, either exterior or interior. Exterior rings are oriented clockwise, while holes are oriented counter-clockwise.
Maybe the OGR driver should be improved to check for this. If more than one exterior ring is found then an OGC multi-polygon geometry object should be returned. Could check the orientation via area or the http://en.wikipedia.org/wiki/Even%E2%80%93odd_rule
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
