[gdal-dev] MSG Driver: two memory leaks
Even Rouault
even.rouault at mines-paris.org
Fri Jun 27 06:56:30 PDT 2014
Selon Simon Richard Proud <srp at geo.ku.dk>:
> Hello,
> We actually stopped using the GDAL MSG driver some time ago (as it is very
> slow) and wrote our own one instead.
Something that you would want to contribute ?
> My mail was mainly to find out if others
> have experienced similar problems.
> The problem is not from the EUMETSAT libraries, by the way. We have been
> using them with very small memory use (they only decompress the data). The
> memory use is coming from somewhere in the reflectance calculations. They
> seem well hidden but, as Christian mentioned, a valgrind could well find
> them.
The GDAL MSG driver is of modest size so that should be not too hard to track
down hopefully.
Do you have samples of such images and the GDAL connection string used ?
Even
> All the best,
> Simon
> ________________________________________
> Fra: Even Rouault [even.rouault at mines-paris.org]
> Sendt: 26. juni 2014 16:48
> Til: gdal-dev at lists.osgeo.org
> Cc: Simon Richard Proud
> Emne: Re: [gdal-dev] MSG Driver: two memory leaks
> Le jeudi 26 juin 2014 16:14:03, Simon Richard Proud a écrit :
> > Hi,
> > Have you noticed any other memory leaks in the MSG driver? We have seen
> > some huge memory uses when working with the visible MSG channels
> > (converting from DN to Reflectance) but have not been able to track down
> > where the memory is being used. Would be good to have a second opinion!
> Simon,
> I just wanted to mention I can be available for contractual support on GDAL
> if
> you need.
> It might not be to be excluded that the leak might be in the Eumetsat library
> itself.
> Best regards,
> Even
> > All the best,
> > Simon
> > Fra: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org]
> > på vegne af Christian Authmann [authmanc at Mathematik.Uni-Marburg.de]
> > Sendt: 26. juni 2014 05:23
> > Emne: [gdal-dev] MSG Driver: two memory leaks
> > Hello,
> > valgrind'ing my application revealed two memory leaks in msgdataset.cpp.
> > a) MSGDataset::pszProjection shall always point to a valid string during
> > the lifetime of the object; the old string needs to be released before
> > getting a new one from exportToWkt().
> > b) A spatial reference is exported to a temporary string as WKT, but the
> > string is never released.
> > Attached you'll find a patch fixing both; valgrind confirms that both
> > memory leaks are gone.
> > Christian Authmann
> > Philipps-Universität Marburg
> > Fachbereich Mathematik und Informatik
> > AG Datenbanksysteme
> > Hans-Meerwein-Straße
> > D-35032 Marburg
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
