[gdal-dev] gdalinfo: fix metadata output
Christian Authmann
authmanc at Mathematik.Uni-Marburg.de
Thu Jun 26 02:35:37 PDT 2014
Hello,
I tried getting a driver to return some useful metadata from the files,
but gdalinfo never displayed any of it. As it turns out, the culprit was
gdalinfo. It will never report metadata from the bands, even if
explicitely requested in the command line.
So I set out to rewrite the metadata handling. It will now use the same
function to display both dataset metadata and band metadata. While I was
at it, I fixed a violation of the DRY-principle, introducing a small
helper function to get a metadata list, loop over it and output everything.
Since there's probably someone out there with a script that parses the
output of gdalinfo, I was careful not to introduce any functional
changes in the output. The only visible difference should be that band
metadata is actually printed.
Patch is attached for review and/or committing.
Christian Authmann
Philipps-Universität Marburg
Fachbereich Mathematik und Informatik
AG Datenbanksysteme
Hans-Meerwein-Straße
D-35032 Marburg
--- a/apps/gdalinfo.c 2014-06-26 13:22:16.980934455 +0200
+++ b/apps/gdalinfo.c 2014-06-25 15:38:11.273797119 +0200
@@ -44,6 +44,13 @@
const char * corner_name,
double x, double y );
+static void
+GDALInfoReportMetadata( GDALMajorObjectH hObject,
+ int bListMDD,
+ int bShowMetadata,
+ char **papszExtraMDDomains,
+ int bIsBand );
/* Usage() */
@@ -78,10 +85,9 @@
int i, iBand;
double adfGeoTransform[6];
GDALDriverH hDriver;
- char **papszMetadata;
int bComputeMinMax = FALSE, bSample = FALSE;
int bShowGCPs = TRUE, bShowMetadata = TRUE, bShowRAT=TRUE;
- int bStats = FALSE, bApproxStats = TRUE, iMDD;
+ int bStats = FALSE, bApproxStats = TRUE;
int bShowColorTable = TRUE, bComputeChecksum = FALSE;
int bReportHistograms = FALSE;
int bReportProj4 = FALSE;
@@ -397,125 +403,8 @@
/* Report metadata. */
- if( bListMDD )
- char** papszMDDList = GDALGetMetadataDomainList( hDataset );
- char** papszIter = papszMDDList;
- if( papszMDDList != NULL )
- printf( "Metadata domains:\n" );
- while( papszIter != NULL && *papszIter != NULL )
- if( EQUAL(*papszIter, "") )
- printf( " (default)\n");
- else
- printf( " %s\n", *papszIter );
- papszIter ++;
- CSLDestroy(papszMDDList);
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hDataset, NULL ) : NULL;
- if( bShowMetadata && CSLCount(papszMetadata) > 0 )
- printf( "Metadata:\n" );
- for( i = 0; papszMetadata[i] != NULL; i++ )
- printf( " %s\n", papszMetadata[i] );
- if( papszExtraMDDomains != NULL && EQUAL(papszExtraMDDomains[0], "all") &&
- papszExtraMDDomains[1] == NULL )
- CSLDestroy(papszExtraMDDomains);
- papszExtraMDDomains = NULL;
- if( !EQUAL(*papszIter, "") &&
- !EQUAL(*papszIter, "IMAGE_STRUCTURE") &&
- !EQUAL(*papszIter, "SUBDATASETS") &&
- !EQUAL(*papszIter, "GEOLOCATION") &&
- !EQUAL(*papszIter, "RPC") )
- papszExtraMDDomains = CSLAddString(papszExtraMDDomains, *papszIter);
- papszIter ++;
- for( iMDD = 0; bShowMetadata && iMDD < CSLCount(papszExtraMDDomains); iMDD++ )
- papszMetadata = GDALGetMetadata( hDataset, papszExtraMDDomains[iMDD] );
- if( CSLCount(papszMetadata) > 0 )
- printf( "Metadata (%s):\n", papszExtraMDDomains[iMDD]);
- if (EQUALN(papszExtraMDDomains[iMDD], "xml:", 4))
- printf( "%s\n", papszMetadata[i] );
- else
-/* Report "IMAGE_STRUCTURE" metadata. */
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hDataset, "IMAGE_STRUCTURE" ) : NULL;
- printf( "Image Structure Metadata:\n" );
-/* Report subdatasets. */
- papszMetadata = GDALGetMetadata( hDataset, "SUBDATASETS" );
- printf( "Subdatasets:\n" );
-/* Report geolocation. */
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hDataset, "GEOLOCATION" ) : NULL;
- printf( "Geolocation:\n" );
+ GDALInfoReportMetadata( hDataset, bListMDD, bShowMetadata, papszExtraMDDomains, FALSE);
-/* Report RPCs */
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hDataset, "RPC" ) : NULL;
- printf( "RPC Metadata:\n" );
/* Setup projected to lat/long transform if appropriate. */
@@ -796,42 +685,7 @@
GDALGetRasterOffset( hBand, &bSuccess ),
GDALGetRasterScale( hBand, &bSuccess ) );
- if( bListMDD )
- char** papszMDDList = GDALGetMetadataDomainList( hBand );
- printf( " Metadata domains:\n" );
- else
- papszIter ++;
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hBand, NULL ) : NULL;
- printf( " Metadata:\n" );
- papszMetadata = (bShowMetadata) ? GDALGetMetadata( hBand, "IMAGE_STRUCTURE" ) : NULL;
- printf( " Image Structure Metadata:\n" );
+ GDALInfoReportMetadata( hBand, bListMDD, bShowMetadata, papszExtraMDDomains, TRUE);
if( GDALGetRasterColorInterpretation(hBand) == GCI_PaletteIndex
&& (hTable = GDALGetRasterColorTable( hBand )) != NULL )
@@ -944,3 +798,126 @@
return TRUE;
+/* GDALInfoPrintMetadata() */
+static void GDALInfoPrintMetadata( GDALMajorObjectH hObject,
+ const char *pszDomain,
+ const char *pszDisplayedname )
+ int i;
+ char **papszMetadata;
+ int bIsxml = FALSE;
+ if (pszDomain != NULL && EQUALN(pszDomain, "xml:", 4))
+ bIsxml = TRUE;
+ papszMetadata = GDALGetMetadata( hObject, pszDomain );
+ if( CSLCount(papszMetadata) > 0 )
+ printf( "%s:\n", pszDisplayedname );
+ for( i = 0; papszMetadata[i] != NULL; i++ )
+ if (bIsxml)
+ printf( "%s\n", papszMetadata[i] );
+ else
+ printf( " %s\n", papszMetadata[i] );
+/* GDALInfoReportMetadata() */
+static void GDALInfoReportMetadata( GDALMajorObjectH hObject,
+ int bListMDD,
+ int bIsBand )
+ /* Report Metadata domains */
+ if( bListMDD )
+ char** papszMDDList = GDALGetMetadataDomainList( hObject );
+ char** papszIter = papszMDDList;
+ if( papszMDDList != NULL )
+ printf( "Metadata domains:\n" );
+ while( papszIter != NULL && *papszIter != NULL )
+ if( EQUAL(*papszIter, "") )
+ printf( " (default)\n");
+ else
+ printf( " %s\n", *papszIter );
+ papszIter ++;
+ CSLDestroy(papszMDDList);
+ if (!bShowMetadata)
+ return;
+ /* Report default Metadata */
+ GDALInfoPrintMetadata( hObject, NULL, "Metadata" );
+ /* Report extra Metadata */
+ if (papszExtraMDDomains != NULL) {
+ char **papszExtraMDDomainsExpanded = NULL;
+ int iMDD;
+ if( EQUAL(papszExtraMDDomains[0], "all") &&
+ papszExtraMDDomains[1] == NULL )
+ if( !EQUAL(*papszIter, "") &&
+ !EQUAL(*papszIter, "IMAGE_STRUCTURE") &&
+ !EQUAL(*papszIter, "SUBDATASETS") &&
+ !EQUAL(*papszIter, "GEOLOCATION") &&
+ !EQUAL(*papszIter, "RPC") )
+ papszExtraMDDomainsExpanded = CSLAddString(papszExtraMDDomainsExpanded, *papszIter);
+ papszIter ++;
+ else
+ papszExtraMDDomainsExpanded = CSLDuplicate(papszExtraMDDomains);
+ for( iMDD = 0; iMDD < CSLCount(papszExtraMDDomainsExpanded); iMDD++ )
+ char pszDisplayedname[256];
+ snprintf(pszDisplayedname, 256, "Metadata (%s)", papszExtraMDDomainsExpanded[iMDD]);
+ GDALInfoPrintMetadata( hObject, papszExtraMDDomainsExpanded[iMDD], pszDisplayedname );
+ CSLDestroy(papszExtraMDDomainsExpanded);
+ /* Report various named metadata. */
+ GDALInfoPrintMetadata( hObject, "IMAGE_STRUCTURE", "Image Structure Metadata" );
+ if (!bIsBand)
+ GDALInfoPrintMetadata( hObject, "SUBDATASETS", "Subdatasets" );
+ GDALInfoPrintMetadata( hObject, "GEOLOCATION", "Geolocation" );
+ GDALInfoPrintMetadata( hObject, "RPC", "RPC Metadata" );
