[gdal-dev] New compression library based on gdal design
Aaron Boxer
boxerab at gmail.com
Sat Mar 1 08:21:14 PST 2014
Hey Seth,
I would love to have some help! Currently I have gathered all the relevant
open-source GPU accelerated code
I could find here:
https://github.com/OpenCodec
My plan is to port an existing CUDA jpeg 2000 library to OpenCL:
https://github.com/OpenCodec/gpu_jpeg2k
My library will be called "ThousandthChicken", after the Seymour Cray quote:
If you were plowing a field, which would you rather use? Two strong oxen or
1024 chickens?<http://www.brainyquote.com/quotes/quotes/s/seymourcra103779.html>
Have a look a the code, if you have some time, and let me know your
thoughts.
Cheers,
Aaron
On Sat, Mar 1, 2014 at 11:06 AM, Seth Price <seth at pricepages.org> wrote:
> I am interested in seeing an OpenCL JPEG2000 decoder/encoder developed. I
> have a bit of experience writing OpenCL kernels. Please contact me if you
> need help.
> ~Seth
> via iPhone
> > On Mar 1, 2014, at 7:27 AM, Aaron Boxer <boxerab at gmail.com> wrote:
> > Hello,
> > I recently started developing an open source jpeg2000 compression
> library using opencl.
> > I would like to base the library design on the very successful gdal
> library design.
> > Can anyone recomend any resources to help me to grok the high level
> design of gdal?
> > Thanks so much,
> > Aaron
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140301/24335830/attachment.html>
