[gdal-dev] C# OGR reading OSM features "stalls"
agerrius
arno at agerrius.nl
Sun Mar 2 06:47:37 PST 2014
Hi all,
I'm using the OGR libraries from a C# application to read OSM data. But I
have a problem now, with a certain file the reading of the features
"stalls". It seems GetNextFeature() never returns anything.
When I use ogrinfo -al on the same file it also seems to stall (probably at
the same point, but not sure about that).
Using this simple code I can reproduce the issue, it stops after 19404
features being read:
Ogr.RegisterAll();
DataSource ds =
Ogr.Open(@"C:\flightsim\work\nantucket\source\geo\osm\nantucket.osm", 0);
for (int i = 0; i < ds.GetLayerCount(); i++)
Layer lay = ds.GetLayerByIndex(i);
Console.WriteLine("Reading layer " + lay.GetName());
int count = 0;
Feature feat = lay.GetNextFeature();
while (feat != null)
Console.WriteLine("feature " + count);
count++;
Console.WriteLine(String.Format("Contains {0} features",
count));
The OSM file was extracted from a bigger file using osmosis, not sure if
that could be part of the issue. I have uploaded the OSM file for testing:
http://www.scenerydesign.org/tmp/nantucket.zip
Is there anything I'm doing wrong here? If the file had some issue I would
expect to get an error thrown.
Thanks,
Arno
View this message in context: http://osgeo-org.1560.x6.nabble.com/C-OGR-reading-OSM-features-stalls-tp5106937.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
