[gdal-dev] C# OGR reading OSM features "stalls"
Even Rouault
even.rouault at mines-paris.org
Mon Mar 3 14:39:45 PST 2014
Arno,
> Now if I enable interleaved reading and add the extra do-while loop around
> my code I get 0 features returned. I only apply the filter to the layer the
> first time I go through the loop.
> Ogr.RegisterAll();
> Gdal.SetConfigOption("OGR_INTERLEAVED_READING", "YES");
> DataSource ds =
> Ogr.Open(@"C:\flightsim\work\nantucket\source\geo\osm\nantucket.osm", 0);
> bool nonEmpty = false;
> bool firstRun = true;
> int count = 0;
> do
> nonEmpty = false;
> Layer lay = ds.GetLayerByName("multipolygons");
> Feature feat;
> if (firstRun)
> Console.WriteLine("Reading layer " +
> lay.GetName());
> lay.SetAttributeFilter("landuse IS NOT NULL");
> feat = lay.GetNextFeature();
> lay.ResetReading();
> while (feat != null)
> nonEmpty = true;
> count++;
> firstRun = false;
> } while (nonEmpty);
> Console.WriteLine(String.Format("Contains {0} features",
> count));
> I think the problem is that no features are found in the first "slice of
> the interleaved reading. So therefore nonEmpty is never set to true and
> the do loop stops directly, while the features that match the filter are
> probably later in the OSM file. But I'm not sure if this assumption is OK.
> Do you see any mistakes in my code?
Te issue has nothing to do with the attribute filter (if you remove it, you
will get 0 results as well), but it is due to the fact that you are not
implementing properly the pattern which is documented in
http://gdal.org/ogr/drv_osm.html.... (grrrrrr !!! :-))
In interleaved mode,you need to iterate over ALL layers, and as many times as
one of them report to have a features, and even on the ones you are not
interested in.
And to apply an attribute filter, before running that read pattern itself, set
the filter on the multipolygons layer.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
