[gdal-dev] WAsP map output for ogr
Even Rouault
even.rouault at mines-paris.org
Sun Mar 9 11:58:12 PDT 2014
my quick review :
- ogrwaspdatasource.cpp :
* change author and copyright to yours
* why do you need #ifdef _WIN32
# include <windows.h>
#endif
* GetLayer() : index start at 0, not 1
* WASP_MERGE: you could use CSLTestBoolean(CSLFetchNameValueDef(
papszOptions, "WASP_MERGE", "YES" ))
- ogrwasplayer.cpp :
* change author to yours
* OGRWAsPLayer::~OGRWAsPLayer(): potential issues with lines with less than
2 points ? (and probably at other places)
* OGRWAsPLayer::WriteRoughness(): oErrorRegion.Intersect( oEnvelope ); at
line 304 is useless
* OGRWAsPLayer::CreateFeature(): GetFieldAsDouble() will return 0 if the
field for the feature is NULL. That might be OK for your use case. If not, you
could use IsFieldSet().
* OGRWAsPLayer::CreateGeomField(): that's OK (except the assert(false)), but
you likely did't need to implement it, unless the source feature has several
geometry fields.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
