[gdal-dev] Extra Decimal places added to ASCII gdal_translate mosaic
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Mar 10 10:25:50 PDT 2014
Hi List,
Bringing back an old thread but with a slight change.
I'm now trying to get GDAL to mosaic and export from the ASCII files to a
GeoTIFF.
But the GeoTIFF writer in GDAL is doing the exact same thing as the ASCII
writer was - it's taking *50.597* (source value) and converting it into
something like *50.596895342423*.
I've tried using both gdal_merge and going via a VRT (gdalbuildvrt -
gdal_translate). The result is the same.
I also tried the *DECIMAL_PRECISION* trick, but gdal informs me:
> Warning 6: Driver GTiff does not support DECIMAL_PRECISION creation option
How do I get GDAL to merge these into a GeoTIFF without altering the data?
Thanks,
Jonathan
On 24 January 2014 16:12, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Thanks Norman. I'd already seen that page but failed to read it!
> However, having tested it, it's not functioning as the manual says.
> As best I can tell, DECIMAL_PRECISION=3 should give me 3 decimal places.
> But what it instead does it give me 3 significant figures. So 98.354 has
> become 98.3.
> This becomes a problem because many of my heights are hovering around 100.
> So some will either have to be 1 character too long to ensure no data loss
> for the rest.
> Is this a bug? The documentation on the page linked to is quite clear it
> should be decimal places.
> Less of an issue, but it also didn't make any difference to:
>> xllcorner 432000.000000000000
>> yllcorner 242000.000000000000
>> cellsize 2.000000000000
> GDAL 1.10.1, released 2013/08/26
> Cheers,
> Jonathan
> On 24 January 2014 15:11, Norman Vine <nhv at cape.com> wrote:
>> try
>> gdal_translate -of AAIGrid -co DECIMAL_PRECISION=3 abc.vrt abc.asc
>> see http://www.gdal.org/frmt_various.html
>> HTH
>> Norman
>> On Jan 24, 2014, at 10:01 AM, Jonathan Moules <
>> Hi List,
>> I'm trying to mosaic some ASCII grid tiles into a single large ASCII file
>> (which can then easily be handled).
>> I'm using this process:
>>> REM Create list of files
>>> dir /b /s *.asc > asc_list.txt
>>> REM Turn into VRT
>>> gdalbuildvrt -srcnodata "-9999" -vrtnodata "0" -a_srs "EPSG:27700"
>>> -input_file_list "asc_list.txt" abc.vrt
>>> REM actual mosaicing
>>> gdal_translate -of AAIGrid abc.vrt abc.asc
>> The input files are like:
>>> ncols 500
>>> nrows 500
>>> yllcorner 243000.000
>>> cellsize 2
>>> nodata_value -9999.0
>>> 98.354 98.449 98.658 98.874 99.038 99.096
>> But the outputs are like:
>> fncols 500
>>> nrows 1000
>>> NODATA_value 0
>>> 98.353996276855469 98.448997497558594 98.657997131347656
>>> 98.874000549316406
>> Suddenly everything has a dozen extra decimal places. Not only does this
>> induce the False Precision problem (we don't have heights to the
>> femtometer!), it also massively increases the filesize.
>> How can I get this to not happen?
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140310/9bf6f967/attachment-0001.html>
