[gdal-dev] Gdal GeoTIFFs in MapInfo
Eric Goddard egoddard1010 at gmail.com
Wed Mar 12 06:46:45 PDT 2014
What about using a world file for the projection info? It is an Esri
thing, but maybe MapInfo will recognize it. Just add a -co TFW=YES to
the gdal_translate command.
Eric
On Wed, Mar 12, 2014 at 7:44 AM, Jonathan Moules
<jonathanmoules at warwickshire.gov.uk> wrote:
> Hi Even,
>> Well, I don't know MapInfo limits with raster files. Perhaps is it just
>> big
>> raster dimensions that cause problem, or tiling, or .. ?
> I guess it's size. I've tried with no compression, no tiles, and both no
> compression or tiling, all fail. So I guess a MapInfo thing then.
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
