[gdal-dev] Enter The Chicken
Piotr Tracz
piotr at cgis.pl
Tue Mar 18 07:02:10 PDT 2014
W dniu 2014-03-18 13:52, Aaron Boxer pisze:
> Thanks for the heads up. What types of changes did you need to make to
> GDAL to make it ICD compatible?
1. NMake build script
2. Linking aganist ICD lib instead of OpenCL SDK (ATI)
3. Config params, which can set OpenCL device runtime (CPLSetConfigOption)
4. OpenCL warp kernel source which can use above changes
Its still work under progress... no ETA.
/Piotr
