[gdal-dev] "Times" projection in GDAL
Jean-Claude Repetto
jrepetto at free.fr
Tue Mar 25 00:35:53 PDT 2014
On 25/03/2014 00:01, Jed O. Kaplan wrote:
> Dear Dmitriy,
> Yes that is the correct projection code, but the problem is - and hence my original question - that the “Times” projection referred to on the link you sent me is not defined in proj4. I’m wondering if anyone has programmed it, or if someone would be so kind as to assist me in making my own code for a new map projection for proj4.
> Many thanks again,
> Jed Kaplan
Hi
I think you are on the wrong mailing list. Have you tried to post a
message on the proj4 ML ?
Jean-Claude
