[gdal-dev] "Times" projection in GDAL
Dmitriy Baryshnikov
bishop.dev at gmail.com
Tue Mar 25 01:04:35 PDT 2014
Hi Jed,
I look at GDAL sources. The Times projection is supported in GDAL/OGR.
For example, you can user ESRI prj file as input parameter (s_srs,
t_srs). for gdalwarp/gdal_translate.
Best regards,
Dmitry
25.03.2014 3:01, Jed O. Kaplan пишет:
> Dear Dmitriy,
> Yes that is the correct projection code, but the problem is - and hence my original question - that the “Times” projection referred to on the link you sent me is not defined in proj4. I’m wondering if anyone has programmed it, or if someone would be so kind as to assist me in making my own code for a new map projection for proj4.
> Many thanks again,
> Jed Kaplan
> On 24 Mar 2014, at 20:38, Dmitriy Baryshnikov <bishop.dev at gmail.com> wrote:
>> Hi Jed,
>> I'm look for this projection on spatialreference.org. I found this one: http://spatialreference.org/ref/sr-org/7670/
>> Does this one the same or close to the ESRI one?
>> Best regards,
>> Dmitry
>> 24.03.2014 22:42, Jed O. Kaplan пишет:
>>> Dear GDAL gurus,
>>> I have some scanned maps in the “Times" projection that I would like to orthorectify using gdalwarp and other GDAL tools. It appears that this projection is not supported in the version of proj4/GDAL that I have, though it seems to be included in most ESRI software (http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//003r00000045000000).
>>> Would anyone happen to know of free software I could use to rectify scanned maps in the Times projection? Alternatively, I could try programming the projection into proj4 myself, though I’ve never done this before. Snyder provides the formulas for the forward projection in his book “Flattening the Earth…” (pg. 213). If I would program a new projection in proj4, are there particular issues I need to be aware of?
>>> Many thanks in advance for your help!
>>> Jed Kaplan
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
