[gdal-dev] gdal-dev Digest, Vol 118, Issue 58
ridgewang
ridgewang at gmail.com
Wed Mar 26 23:21:33 PDT 2014
I have 2 suggestions:
1. supply an option that can build the gdal using the static c++ runtime library, so we can use it not depends on the msvcr80.dll and msvcp80.dll.
2. provide a gdal_merge.exe utility program with the same function as gdal_merge.py.
here are the reasons I raise it:
1. I write a COM component using gdal library, but I can not register the component correction, maybe the version in my computer is not right and I donot known how to build a static version not using the vc runtime library.
2. I do not known how to run the python utility and it always reports cannot find the _gdal module, and I had tried many times and had set the pythonpath environment variance.
And who can kindly teach me how to solve the first problem. Maybe I can add some switch option to the compile configuration file?
Ridge
在 2014-3-27,3:00,gdal-dev-request at lists.osgeo.org 写道:
> Send gdal-dev mailing list submissions to
> gdal-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
> 1. Re: GDAL 1.11 release plan (Even Rouault)
> Message: 1
> Date: Wed, 26 Mar 2014 16:16:24 +0100
> From: Even Rouault <even.rouault at mines-paris.org>
> To: Olivier BARTHELEMY <barthelemy at geovariances.com>
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL 1.11 release plan
> Message-ID: <1395846984.5332ef48e324c at imp.free.fr>
> Content-Type: text/plain; charset=ISO-8859-15
> Selon Olivier BARTHELEMY <barthelemy at geovariances.com>:
> I've fixed the one in adrgdataset.cpp.
> gifalloc.c, degrib18, hdf-eos are third-party code "imported" into GDAL tree. So
> the best way would be to fix the issues upstream (if fix is actually needed) and
> then downstream into GDAL.
> I've analyze errors reported in rasterlitedataset.cpp, ogrdatasource.cpp,
> ogrpgdatasource.cpp and strtod, and they are false positives. So the rate of
> false positives with cppcheck is quite significant.
> I haven't looked at the other files that I'm less familiar with.
> Even
>> Here is what cppcheck 1.64 reports as 'errors' in gdal-1.10.1:
>> [frmts\adrg\adrgdataset.cpp:1071]: (error) Memory leak: TILEINDEX
>> [frmts\coasp\coasp_dataset.cpp:199]: (error) Undefined behavior: Variable
>> 'pszItemValue' is used as parameter and destination in s[n]printf().
>> [frmts\dted\dted_create.c:181]: (error) Resource leak: fp
>> [frmts\envisat\EnvisatFile.c:286]: (error) Memory leak: self
>> [frmts\envisat\EnvisatFile.c:609]: (error) Memory leak: dsd_text
>> [frmts\envisat\EnvisatFile.c:1776]: (error) Memory leak: entry
>> [frmts\georaster\georaster_dataset.cpp:188]: (error) Possible null pointer
>> dereference: poGRD
>> [frmts\georaster\georaster_dataset.cpp:189]: (error) Possible null pointer
>> dereference: poGRD
>> [frmts\georaster\georaster_dataset.cpp:190]: (error) Possible null pointer
>> dereference: poGRD
>> [frmts\georaster\georaster_dataset.cpp:191]: (error) Possible null pointer
>> dereference: poGRD
>> [frmts\georaster\oci_wrapper.cpp:1590]: (error) Pointer to local array
>> variable returned.
>> [frmts\gif\giflib\gifalloc.c:67]: (error) Memory leak: Object
>> [frmts\grib\degrib18\degrib\clock.c:2071]: (error) Common realloc mistake:
>> 'Stack' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\clock.c:2175]: (error) Common realloc mistake:
>> 'Rel' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\clock.c:2197]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\clock.c:2209]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\grib2api.c:594]: (error) Uninitialized
>> variable: igdstmpl
>> [frmts\grib\degrib18\degrib\metaparse.cpp:2628]: (error) Common realloc
>> mistake: 'freq' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\myerror.c:109]: (error) Common realloc mistake:
>> 'buffer' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\myerror.c:126]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:132]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:149]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:158]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:187]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:195]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:203]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:211]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:218]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:229]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:241]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:257]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myerror.c:442]: (error) Common realloc mistake:
>> 'preBuffer' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\myerror.c:534]: (error) Common realloc mistake:
>> 'buff' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\myutil.c:85]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myutil.c:92]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myutil.c:99]: (error) Common realloc mistake:
>> [frmts\grib\degrib18\degrib\myutil.c:149]: (error) Common realloc mistake:
>> 'argv' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\tdlpack.cpp:3256]: (error) Common realloc
>> mistake: 'subGroup' nulled but not freed upon failure
>> [frmts\grib\degrib18\degrib\tdlpack.cpp:4179]: (error) Read and write
>> operations without a call to a positioning function (fseek, fsetpos or
>> rewind) or fflush in between result in undefined behaviour.
>> [frmts\grib\degrib18\g2clib-1.0.4\compack.c:159]: (error) Uninitialized
>> variable: ival1
>> [frmts\grib\degrib18\g2clib-1.0.4\comunpack.c:198]: (error) Memory leak:
>> ifld
>> [frmts\grib\degrib18\g2clib-1.0.4\misspack.c:203]: (error) Uninitialized
>> variable: ival1
>> [frmts\grib\degrib18\g2clib-1.0.4\misspack.c:118]: (error) Uninitialized
>> variable: rmisss
>> [frmts\grib\degrib18\g2clib-1.0.4\pngunpack.c:61]: (error) Memory leak: ifld
>> ctemp
>> [frmts\hdf4\hdf-eos\EHapi.c:2315]: (error) Common realloc mistake:
>> 'metabuf' nulled but not freed upon failure
>> [frmts\hdf4\hdf-eos\EHapi.c:3665]: (error) Common realloc mistake:
>> 'EHXtypeTable' nulled but not freed upon failure
>> [frmts\hdf4\hdf-eos\EHapi.c:3668]: (error) Common realloc mistake:
>> 'EHXacsTable' nulled but not freed upon failure
>> [frmts\hdf4\hdf-eos\EHapi.c:3671]: (error) Common realloc mistake:
>> 'EHXfidTable' nulled but not freed upon failure
>> [frmts\hdf4\hdf-eos\EHapi.c:3674]: (error) Common realloc mistake:
>> 'EHXsdTable' nulled but not freed upon failure
>> [frmts\hdf4\hdf-eos\GDapi.c:2411]: (error) Array 'HDFcomp[5]' accessed at
>> index 19, which is out of bounds.
>> [frmts\hdf4\hdf-eos\GDapi.c:2177]: (error) Array 'originNames[4]' accessed
>> at index 15, which is out of bounds.
>> [frmts\hdf4\hdf-eos\GDapi.c:2292]: (error) Array 'pixregNames[2]' accessed
>> at index 7, which is out of bounds.
>> [frmts\hdf4\hdf-eos\SWapi.c:4995]: (error) Memory leak: fillbuf
>> [frmts\hdf4\hdf-eos\SWapi.c:5615]: (error) Memory leak: flag
>> [frmts\hdf4\hdf-eos\SWapi.c:6239]: (error) Memory leak: flag
>> [frmts\idrisi\IdrisiDataset.cpp:1886]: (error) syntax error
>> [frmts\ilwis\ilwisdataset.cpp:1425]: (error) syntax error
>> [frmts\msg\msgdataset.cpp:532]: (error) Object pointed by an 'auto_ptr' is
>> destroyed using operator 'delete'. You should not use 'auto_ptr' for
>> pointers obtained with operator 'new[]'.
>> [frmts\netcdf\netcdfdataset.cpp:5997]: (error) Uninitialized variable:
>> strtime
>> [frmts\pcidsk\sdk\core\pcidsk_utils.cpp:644]: (error) Common realloc
>> mistake: 'pszWorkBuffer' nulled but not freed upon failure
>> [frmts\pcidsk\sdk\core\pcidskexception.cpp:170]: (error) Common realloc
>> [frmts\png\libpng\pngrutil.c:996]: (error) Uninitialized variable: igamma
>> [frmts\rasterlite\rasterlitedataset.cpp:1179]: (error) Possible null
>> pointer dereference: poDS
>> [frmts\rasterlite\rasterlitedataset.cpp:1185]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1186]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1187]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1188]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1190]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1191]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1192]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1193]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1194]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1195]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1196]: (error) Possible null
>> [frmts\rasterlite\rasterlitedataset.cpp:1267]: (error) Possible null
>> [frmts\raw\atlsci_spheroid.cpp:122]: (error) syntax error
>> [frmts\raw\mffdataset.cpp:1451]: (error) syntax error
>> [frmts\sgi\sgidataset.cpp:523]: (error) Using 'memcpy' on struct that
>> contains a 'std::string'.
>> [ogr\ogrsf_frmts\dgn\dgnhelp.cpp:1379]: (error) syntax error
>> [ogr\ogrsf_frmts\dwg\ogrdwglayer.cpp:323]: (error) Invalid number of
>> character ({) when these macros are defined: 'notdef'.
>> [ogr\ogrsf_frmts\filegdb\FGdbLayer.cpp:1914]: (error) syntax error
>> [ogr\ogrsf_frmts\generic\ogrdatasource.cpp:1425]: (error) Possible null
>> pointer dereference: papoSrcLayers
>> [ogr\ogrsf_frmts\mitab\mitab_coordsys.cpp:747]: (error) Buffer is accessed
>> out of bounds.
>> [ogr\ogrsf_frmts\mitab\mitab_geometry.cpp:223]: (error) Memory leak:
>> xintersect
>> [ogr\ogrsf_frmts\ntf\ntffilereader.cpp:260]: (error) Memory pointed to by
>> 'poRecord' is freed twice.
>> [ogr\ogrsf_frmts\pg\ogrpgdatasource.cpp:1102]: (error) Memory leak: poLayer
>> [ogr\ogrsf_frmts\shape\shptree.c:241]: (error) Memory leak: psTree
>> [port\cpl_minizip_zip.cpp:608]: (error) Memory leak: zi
>> [port\cpl_strtod.cpp:67]: (error) Division by zero.
>> I'd be happy to provide fix patches, but i have not much time at the
>> moment, so it won't be before a 1.11 release.
>> If you want to see the other 'warnings', and get un updated report on GDAL
>> trunk, maybe you could ask to those who manage
>> http://debbie.postgis.net:8080/view/GDAL/ to add the cppcheck plugin to
>> their Jenkins?
>> 2014-03-26 9:15 GMT+01:00 Even Rouault <even.rouault at mines-paris.org>:
>>> Hi Olivier,
>>> If you could share with us the errors that have been reported (and the
>>> options
>>> you have used to pass cppcheck on GDAL source), that would be a good
>>> contribution. Even better if you can submit a patch to fix them ;-)
>>> Not saying they shouldn't be fixed, but I don't see that as a blocker point
>>> however, unless they show up in nominal code paths. They have likely
>>> existed for
>>> years.
>>> We also have registered GDAL to the Coverity scanner, and we try to fix
>>> errors
>>> that are reported in new code.
>>> Even
>>>> I think you should take a look at what cppcheck finds when scanning GDAL
>>>> source before the next release. There are a few tens of small errors.
>>>> Mostly, small leaks in particalr cases. Not very important errors, but
>>> that
>>>> ought to be fixed before doing an release in my opinion
>>>> 2014-03-26 8:49 GMT+01:00 Paul Meems <bontepaarden at gmail.com>:
>>>>> +1 for adding VS2013 binaries in GISInternals
>>>>> Thanks,
>>>>> Paul
>>>>> *Paul Meems *
>>>>> Release manager, configuration manager
>>>>> and forum moderator of MapWindow GIS.
>>>>> www.mapwindow.org
>>>>> Owner of MapWindow.nl - Support for
>>>>> Dutch speaking users.
>>>>> www.mapwindow.nl
>>>>> *Join us at the MapWindow GIS Conference 2014
>>>>> <http://geogis.detek.unideb.hu/TKonferencia/2014/>, in Debrecen
>>> Hungary*
>>>>> 2014-03-26 6:25 GMT+01:00 xavier lhomme <lhomme.xavier at gmail.com>:
>>>>> Hi
>>>>>> Adding Visual Studio 2012 2013 in GISInternals for Gdal 1.11 should
>>> be
>>>>>> great too.
>>>>>> Xav
>>>>>> Le 25 mars 2014 22:57, "Tamas Szekeres" <szekerest at gmail.com> a
>>> ?crit :
>>>>>> That sounds good to me.
>>>>>>> Best regards,
>>>>>>> Tamas
>>>>>>> 2014-03-25 22:37 GMT+01:00 Even Rouault <
>>>>>>>> Hi,
>>>>>>>> GDAL 1.10 was released about one year ago, so it is time to think
>>> about
>>>>>>>> the next
>>>>>>>> release. I think we should just call it 1.11 given that there are no
>>>>>>>> major
>>>>>>>> architectural changes (although there have been non trivial changes
>>> in
>>>>>>>> RAT
>>>>>>>> management and for multiple geometry field support, but that only
>>>>>>>> impacts core &
>>>>>>>> drivers), and the C API and ABI is still preserved (for those who
>>> have
>>>>>>>> looked at
>>>>>>>> the other thread, my experiments on unification are *not* in trunk).
>>>>>>>> For the
>>>>>>>> details, I have initiated the preliminary NEWS :
>>>>>>>> http://trac.osgeo.org/gdal/export/27091/trunk/gdal/NEWS (*)
>>>>>>>> There are some mentions to 2.0 in the documentation of new features,
>>>>>>>> but I'll
>>>>>>>> end up fixing them to reflect the 1.11 numbering.
>>>>>>>> I think we are in a good shape to start the beta phase soon. If
>>> people
>>>>>>>> have
>>>>>>>> features or bug fixes almost ready that they'd like to be in 1.11,
>>>>>>>> please speak
>>>>>>>> up now. Otherwise I suggest issuing a beta-1 at the end of next
>>> week,
>>>>>>>> give it a
>>>>>>>> week for testing, and depending on the outcome, issue a beta-2, or
>>> just
>>>>>>>> try
>>>>>>>> RC-1. Unless someone volunteers (the process is fairly well
>>> documented
>>>>>>>> in
>>>>>>>> HOWTO-RELEASE), I can be release manager for 1.11.
>>>>>>>> Any opinion about that plan ?
>>>>>>>> Best regards,
>>>>>>>> Even
>>>>>>>> Geospatial professional services
>>>>>>>> http://even.rouault.free.fr/services.html
>>>>>>>> _______________________________________________
>>>> [image: Geovariances]
>>>> Olivier BARTHELEMY *Software development engineer*
>>>> Geovariances, 49bis avenue Franklin Roosevelt - 77215 AVON CEDEX - FRANCE
>>>> | www.geovariances.com <http://link.geovariances.com/eml-home>
>>>> Keep posted about Geovariances <
>>> http://link.geovariances.com/eml-geowidget>
>>>> <http://link.geovariances.com/eml-linkedin-gv>
>>>> <http://link.geovariances.com/eml-linkedin>
>>>> <http://link.geovariances.com/eml-twitter>
>>>> <http://link.geovariances.com/eml-youtube>
>>>> <http://link.geovariances.com/eml-slideshare>
>> Keep posted about Geovariances <http://link.geovariances.com/eml-geowidget>
> End of gdal-dev Digest, Vol 118, Issue 58
