On 27/03/2014 07:21, ridgewang wrote: > Hi, > I have 2 suggestions: > 1. supply an option that can build the gdal using the static c++ runtime library, so we can use it not depends on the msvcr80.dll and msvcp80.dll. > Hi, You can use gdalwarp to merge several files.
