[gdal-dev] Open WMS datasets with GDAL Java
Fabio Rinnone
fabio.rinnone0 at gmail.com
Fri Mar 28 03:43:30 PDT 2014
Il 27/03/2014 20:09, Etienne Tourigny ha scritto:
> Have you tried running in debug mode (CPL_DEBUG=ON)?
Can I do this? I have added the following:
gdal.SetConfigOption("CPL_DEBUG", "ON");
before calling of gdal.AllRegister() but does not seem to appear new log
messages in standard error when I try to open WMS dataset.
> On Thu, Mar 27, 2014 at 3:37 PM, Fabio Rinnone <fabio.rinnone0 at gmail.com
> <mailto:fabio.rinnone0 at gmail.com>> wrote:
> Il 27/03/2014 18:27, Even Rouault ha scritto:
> > Selon Fabio Rinnone <fabio.rinnone0 at gmail.com
> <mailto:fabio.rinnone0 at gmail.com>>:
> >> Hi, I'm trying to open datasets of WMS service with GDAL Java
> warp in an
> >> Android app project with native support. Opening datasets always
> returns
> >> null datasets. An example WMS is the following:
> >> http://kaart.maakaart.ee/geoserver/wms
> >> I use following statements:
> >> name = "WMS:http://kaart.maakaart.ee/geoserver/wms";
> >> gdal.Open(name);
> >> For my implementation I have adapted python sample code found
> here[2].
> > I guess you lack a call to gdal.AllRegister(); that will register
> the WMS driver
> > (in Python the registration of drivers is automatically done)
> I'm tried but I have no solved the issue.
> I thought the problem could be related to the inclusion of curl
> libraries (which are required to support WMS), but they are correctly
> included in Android.mk makefile.
> Do you have other suggestions?
> Fabio Rinnone
> 93015 Niscemi CL, Italia
> Skype: fabiorinnone
> Web: http://www.fabiorinnone.eu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
Fabio Rinnone
Skype: fabiorinnone
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140328/0a79d265/attachment-0001.pgp>
