[gdal-dev] Open WMS datasets with GDAL Java
Even Rouault
even.rouault at mines-paris.org
Fri Mar 28 03:54:27 PDT 2014
Does gdal.GetDriverByName("WMS") return a non null pointer ?
> Il 27/03/2014 20:09, Etienne Tourigny ha scritto:
> > Have you tried running in debug mode (CPL_DEBUG=ON)?
> Can I do this? I have added the following:
> gdal.SetConfigOption("CPL_DEBUG", "ON");
> before calling of gdal.AllRegister() but does not seem to appear new log
> messages in standard error when I try to open WMS dataset.
> > On Thu, Mar 27, 2014 at 3:37 PM, Fabio Rinnone <fabio.rinnone0 at gmail.com
> > <mailto:fabio.rinnone0 at gmail.com>> wrote:
> > Il 27/03/2014 18:27, Even Rouault ha scritto:
> > > Selon Fabio Rinnone <fabio.rinnone0 at gmail.com
> > <mailto:fabio.rinnone0 at gmail.com>>:
> > >> Hi, I'm trying to open datasets of WMS service with GDAL Java
> > warp in an
> > >> Android app project with native support. Opening datasets always
> > returns
> > >> null datasets. An example WMS is the following:
> > >> http://kaart.maakaart.ee/geoserver/wms
> > >> I use following statements:
> > >> name = "WMS:http://kaart.maakaart.ee/geoserver/wms";
> > >> gdal.Open(name);
> > >> For my implementation I have adapted python sample code found
> > here[2].
> > > I guess you lack a call to gdal.AllRegister(); that will register
> > the WMS driver
> > > (in Python the registration of drivers is automatically done)
> > I'm tried but I have no solved the issue.
> > I thought the problem could be related to the inclusion of curl
> > libraries (which are required to support WMS), but they are correctly
> > included in Android.mk makefile.
> > Do you have other suggestions?
> > Fabio Rinnone
> > 93015 Niscemi CL, Italia
> > Skype: fabiorinnone
> > Web: http://www.fabiorinnone.eu
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Fabio Rinnone
> Skype: fabiorinnone
