[gdal-dev] Open WMS datasets with GDAL Java
Fabio Rinnone
fabio.rinnone0 at gmail.com
Fri Mar 28 04:06:32 PDT 2014
Il 28/03/2014 11:54, Even Rouault ha scritto:
> Does gdal.GetDriverByName("WMS") return a non null pointer ?
It returns an org.gdal.gdal.Driver object. I think this is correctly, right?
>> Il 27/03/2014 20:09, Etienne Tourigny ha scritto:
>>> Have you tried running in debug mode (CPL_DEBUG=ON)?
>> Can I do this? I have added the following:
>> gdal.SetConfigOption("CPL_DEBUG", "ON");
>> before calling of gdal.AllRegister() but does not seem to appear new log
>> messages in standard error when I try to open WMS dataset.
>>> On Thu, Mar 27, 2014 at 3:37 PM, Fabio Rinnone <fabio.rinnone0 at gmail.com
>>> <mailto:fabio.rinnone0 at gmail.com>> wrote:
>>> Il 27/03/2014 18:27, Even Rouault ha scritto:
>>> > Selon Fabio Rinnone <fabio.rinnone0 at gmail.com
>>> <mailto:fabio.rinnone0 at gmail.com>>:
>>> >> Hi, I'm trying to open datasets of WMS service with GDAL Java
>>> warp in an
>>> >> Android app project with native support. Opening datasets always
>>> returns
>>> >> null datasets. An example WMS is the following:
>>> >> http://kaart.maakaart.ee/geoserver/wms
>>> >> I use following statements:
>>> >> name = "WMS:http://kaart.maakaart.ee/geoserver/wms";
>>> >> gdal.Open(name);
>>> >> For my implementation I have adapted python sample code found
>>> here[2].
>>> > I guess you lack a call to gdal.AllRegister(); that will register
>>> the WMS driver
>>> > (in Python the registration of drivers is automatically done)
>>> I'm tried but I have no solved the issue.
>>> I thought the problem could be related to the inclusion of curl
>>> libraries (which are required to support WMS), but they are correctly
>>> included in Android.mk makefile.
>>> Do you have other suggestions?
>>> Fabio Rinnone
>>> 93015 Niscemi CL, Italia
>>> Skype: fabiorinnone
>>> Web: http://www.fabiorinnone.eu
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Fabio Rinnone
>> Skype: fabiorinnone
Fabio Rinnone
Skype: fabiorinnone
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140328/3398c2ba/attachment.pgp>
