[gdal-dev] OGR: memory leak in OCI driver
    SIMON Nicolas
    nicolas.simon at spw.wallonie.be
    Tue May  6 08:32:09 PDT 2014
Dear developers,
                I suspect that there is a memory leak in OCI driver for OGR
                My simplified test case is :
// point A
OGRRegisterAll();
// point B
pDS = OGRSFDriverRegistrar::Open("OCI:USER/PWD at INSTANCE:TABLE", true);
if(pDS)
          OGRDataSource::DestroyDataSource(pDS);
          pDS = NULL;
     else
          fprintf(fOut,"Erreur Open\n");
     // point C
OGRCleanupAll();
// point D
It appears that I lose memory between points B and C, and between point A and D
                B = A + 4 MB
                C = A + 20 MB ( 16 MB lost)
               D = A +19 MB ( 3 more MB lost)
Test was done with GDAL 1.9 under windows (with Oracle 11g)
Can some one have an idea to find and fix this ?
Thank you
By the way,  I received < TICKET_CREATE privileges are required to perform this operation > when I tried to make a ticket (UID nicsim)
Nicolas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140506/02510f87/attachment.html>
