[gdal-dev] OGRLineString Project
Ochs, Elke ERDC-RDE-CRREL-NH
Elke.Ochs at erdc.dren.mil
Thu May 15 13:26:43 PDT 2014
Hello,
The class reference for OGRLineString says Project is available at OGR 1.11.0, GEOS >= 3.2.0. I'm using Python 2.7, OGR 1.11.0, GEOS 3.4.2, but can't locate the Project method. Is it really in 1.11.0? Someone smarter than I said it seems to be missing from the SWIG interface (hope I said that right). If Project isn't implemented, yet, will it be soon?
The syntax I've tried is:
MyLineGeometry.Project(MyPointGeometry)
I get the following error:
AttributeError: Project
This functionality is available through Shapely, but I need to limit use of additional dependencies.
Thank you for any help,
Elke
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140515/afe24225/attachment.html>
