[gdal-dev] OGRLineString Project
Dmitriy Baryshnikov
bishop.dev at gmail.com
Thu May 15 23:56:29 PDT 2014
Hi Elk,
The Project method (and several others) present in GDAL sinvce 1.11, but
there is no binding to python yet.
About dates/releases when it'll be coded - hard to say, maybe somebody
provide a patch with such functionality.
Best regards,
Dmitry
16.05.2014 00:26, Ochs, Elke ERDC-RDE-CRREL-NH ?????:
> Hello,
> The class reference for OGRLineString says Project is available at OGR
> 1.11.0, GEOS >= 3.2.0. I'm using Python 2.7, OGR 1.11.0, GEOS 3.4.2,
> but can't locate the Project method. Is it really in 1.11.0? Someone
> smarter than I said it seems to be missing from the SWIG interface
> (hope I said that right). If Project isn't implemented, yet, will it
> be soon?
> The syntax I've tried is:
> MyLineGeometry.Project(MyPointGeometry)
> I get the following error:
> AttributeError: Project
> This functionality is available through Shapely, but I need to limit
> use of additional dependencies.
> Thank you for any help,
> Elke
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140516/45da40be/attachment.html>
