[gdal-dev] OSM driver to create separate tables for tags
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Thu May 15 14:24:12 PDT 2014
Andre Joost <andre+joost <at> nurfuerspam.de> writes:
> But import time does not matter for me , as it is done only once. I was
> rather thinking about rendering time. From the postgis database, I can
> select a column "network" and style my cycle paths according to the
> values "icn","ncn","rcn","lcn". Pretty much the same as I would do it
> with a shapefile.
> I guess this needs different handling with your tag table approach.
Couple of years ago I was told that such arrangement would be all too slow
for rendering https://groups.google.com/forum/#!topic/openstreetmap/aslKT7-OcLQ
I did not believe and I made some experiments and measured that in my
rendering test joined tables were faster than the standard osm2pgsql tables.
Not a surprise for me because osm2pgsql does not create indexes for the
attribute columns but my renderer was using them in selects. In the tag
table I had indexes on all columns. I prepered a test Spatialite DB then and
it is still online at http://latuviitta.org/documents/relation_test.zip
-Jukka Rahkonen-
