[gdal-dev] issues with gdal2tiles.py
Marcela Campo
marcelacampo at gmail.com
Tue May 27 09:45:23 PDT 2014
Hi André, thank you for your response.
I am not using EPSG:900913 anywhere
I got some img files someone else processed in arcgis and I am processing
them this way:
gdal_translate -of GTIFF -co "COMPRESS=LZW" -scale 0 255 0 255 -ot Byte
input.img input.tif
gdalwarp -t_srs "EPSG:3857" input.tif output_p.tif
gdal2tiles.py output_p.tif
I tried forcing the source projection during warp this way
gdalwarp -s_srs "EPSG:22184" -t_srs "EPSG:3857" input.tif output_p.tif
I am not sure about source projection, I found it out doing:
gdalinfo -proj4 input.img
and searching for the proj4 string in the internet. The image is actually
from the zone of projection EPSG:22184 so I believe is ok.
In what point of the process you say I should be forcing with a_srs?
Thanks!
Marcela
On Tue, May 27, 2014 at 11:53 AM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 27.05.2014 05:31, schrieb Marcela Campo:
> Hi,
>> I am trying to use gdal2tiles with a set of geotiff and I get the
>> following error
>> ERROR 6: EPSG PCS/GCS code 900913 not found in EPSG support files. Is
>> this
>> a valid
>> EPSG coordinate system?
>> ERROR 6: No translation for an empty SRS to PROJ.4 format is known.
>> I have already transformed to projection EPSG:3857, here is the gdalinfo
>> output for one of the files
> the command generates the tiles, but as the images appear a bit shifted I
>> wonder if it somewhat misinterpreted the projection.
> Instead of reprojecting to EPSG:900913 (which will place the points on the
> same spot on the globe), try to assign the projection with -a_srs. This
> will effectively shift the points.
> If the shift goes in the wrong direction, try EPSG:3395. This is the
> projection on a ellipsoid rather than a sphere.
> HTH,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140527/51dcff79/attachment.html>
