[gdal-dev] Store GDAL Result Raster in PostGIS Directly
zlzhao1104
zlzhao1104 at gmail.com
Wed May 28 18:11:34 PDT 2014
Hi I'm a new GDAL/PostGIS user. This question might be simple to you:
I need to use gdal_translate to clip a raster, which is already stored in
PostGIS. I could do it by using "PG" to link to my PostGIS database and I
could store the result as a tiff file on my disk:
gdal_translate -projwin -120.01969132 35.8820930603 -119.47058351
35.1172643251 "PG: dbname=geodb host=localhost user=postgres password=xxxxxx
port=5432 mode=2 schema=public table=srtm_ca" test.tiff
I'm wondering if there is a way to store the result raster directly to my
PostGIS database as a table. I tried to replace "test.tiff" above to
"PG:......" but GDAL still generated a raster on my disk named "PG:......".
Thanks in advance for any ideas and sorry to bother others.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Store-GDAL-Result-Raster-in-PostGIS-Directly-tp5143022.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
