[gdal-dev] VRTBuilder class
Paolo Cavallini
cavallini at faunalia.it
Wed May 28 23:35:10 PDT 2014
Il 28/05/2014 21:14, Siebe Bosch ha scritto:
> If you want to use the VRTBuilder inside your own programming environment (on
> Windows) you could also start using the MapWinGIS ActiveX control.
> Version 4.9 and later supports GDAL, including the VRTBuilder function.
Or you can use Processing in QGIS to automatically create a Python script for this.
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
