[gdal-dev] How to get value of Spatial Attributes Ogr Provider
Dao Thang
thanghps at gmail.com
Mon Nov 10 19:28:12 PST 2014
Hi Chaitanya,
Thanks again.
As i told, my data don't have layer M_SREL. But other application can read
my data and show the QUAPOS attribute.
So this attribute is not in that layer as you told.
*Đào Trọng Thắng*
*Mobile:* 0919 262 988
Tầng 11 - Handi Resco Building
521 Kim Mã - Hà Nội
*Email: thanghps at gmail.com <thanghps at gmail.com>*
*YM **:** daothang2004*
Google Talk: thanghps Skype: thanghps
Contact Me [image: Facebook] <http://facebook.com/thanghps>[image: Twitter]
<http://twitter.com/thanghps>
<http://my.wisestamp.com/link?u=mjd9tz39tqz5jn9m&site=www.wisestamp.com/email-install>
On Mon, Nov 10, 2014 at 8:02 PM, Chaitanya kumar CH <chaitanya.ch at gmail.com>
wrote:
> Thang,
> I don't have access to any ENC viewer now. However, AFAIK, M_SREL is a
> special layer. So, you might be getting attributes from that layer. If you
> do need that data, you can get the feature from that location and use it.
> On 10 Nov 2014 11:58, "Dao Thang" <thanghps at gmail.com> wrote:
>> Hi Chaitanya,
>> My s57 file don't have M_SREL layer.
>> Note: If i open it with EasyViewer App of Caris, i can see QUAPOS
>> atrribute.
>> Please check it again.
>> Thanks for your time!
>> Thang
>> *Đào Trọng Thắng*
>> 521 Kim Mã - Hà Nội
>> Twitter] <http://twitter.com/thanghps>
>> On Mon, Nov 10, 2014 at 11:50 AM, Chaitanya kumar CH <
>> chaitanya.ch at gmail.com> wrote:
>>> Đào,
>>> You can look for the M_SREL feature in the required area and read it's
>>> attributes.
>>> You can apply a spatial filter on the M_SREL layer with the particular
>>> DEPCNT feature.
>>> Also, note that the DEPCNT features are often not very accurate.
>>> On Mon, Nov 10, 2014 at 10:03 AM, Dao Thang <thanghps at gmail.com> wrote:
>>>> Hi Chaitanya,
>>>> QUAPOS is not attribute of feature object of Depth contour. I know that.
>>>> But QUAPOS that i searching is spatial attribute of Spatial object. You
>>>> can read S57 specification to know Spatial Attribute.
>>>> Thanks
>>>> *Đào Trọng Thắng*
>>>> 521 Kim Mã - Hà Nội
>>>> On Mon, Nov 10, 2014 at 11:22 AM, Chaitanya kumar CH <
>>>>> Đào,
>>>>> Refer to http://www.s-57.com/
>>>>> Depth contour features don't have a Quality of position attribute.
>>>>> On Mon, Nov 10, 2014 at 7:29 AM, Dao Thang <thanghps at gmail.com> wrote:
>>>>>> Hi All,
>>>>>> I used sharpmap with ogr provider to read S57 file.
>>>>>> But i don't see the spatial attributes example: QUAPOS attribute in
>>>>>> the DEPCNT layer.
>>>>>> Does anyone help me get it.
>>>>>> Thanks
>>>>>> [image: Inline image 1]
>>>>>> *Đào Trọng Thắng*
>>>>>> 521 Kim Mã - Hà Nội
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Best regards,
>>>>> Chaitanya kumar CH.
>>>>> +91-9494447584
>>>>> 17.2416N 80.1426E
>>> Best regards,
>>> Chaitanya kumar CH.
>>> +91-9494447584
>>> 17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141111/42526a37/attachment-0001.html>
