[gdal-dev] creating graph for single line shape layer using gdal gnm
yhema
hema.yeedunuri at amigooptima.in
Mon Nov 10 23:26:44 PST 2014
Hello all,
I am trying to create a graph for network analysis using gdalgnm.The feature
auto connect is working if we provide more than one layer.How can we connect
features of a single layer so that graph is created automatically. We can
connect features using connect features but automatically it is not
conncting using auto connect .Here is the code.
char **options = NULL;
options = CSLAddNameValue(options,GNM_INIT_OPTIONPAIR_NAME,
"roads_network");
GNMGdalNetwork *poNet;
poNet =
GNMManager::GdalCreateNetwork("/home/shiva/Desktop/network/network_data",
"ESRI Shapefile", "EPSG:4326", options);
CSLDestroy(options);
if (poNet == NULL)
printf("Failed to create network\n");
exit(1);
GDALDataset *poSrcDS = (GDALDataset*)
GDALOpenEx("/home/shiva/Desktop/network/data",
GDAL_OF_VECTOR |
GDAL_OF_READONLY, NULL, NULL, NULL );
if(poSrcDS == NULL)
printf("Can not open source dataset at\n");
exit(1);
OGRLayer *poSrcLayer2 = poSrcDS->GetLayerByName("roads");
if (poSrcLayer2 == NULL)
printf("layer is null\n");
printf("Can not process layers of source dataset\n");
exit(1);
GNMErr err2 = poNet->CopyLayer(poSrcLayer2, "roads");
if (err2 != GNMERR_NONE)
printf("Can not import layers from source dataset\n");
exit(1);
GDALClose(poSrcDS);
if (poNet->CreateRule("CLASS gnm_roads_line COSTS TIGER_ID") !=
GNMERR_NONE)
printf("Can not create rule\n");
if (poNet->CreateRule("NETWORK CONNECTS gnm_roads_line WITH
gnm_roads_line ") != GNMERR_NONE)
printf("\nBuilding network topology ...\n");
GDALDataset *poNetDS = poNet->GetDataset();
OGRLayer **layers = new OGRLayer*[3];
layers[0] = poNetDS->GetLayerByName("gnm_roads_line");
layers[2] = NULL;
layers[1] = NULL;
if (poNet->AutoConnect(layers,0.05, NULL) != GNMERR_NONE)
printf("Building topology failed\n");
exit(1);
else
printf("Topology has been built successfully\n");
delete[] layers;
GNMManager::GdalCloseNetwork(poNet);
thanks,
hema
View this message in context: http://osgeo-org.1560.x6.nabble.com/creating-graph-for-single-line-shape-layer-using-gdal-gnm-tp5172326.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
