[gdal-dev] LZW Compression on geotiffs
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Thu Oct 2 00:55:17 PDT 2014
Rahkonen Jukka (Tike <jukka.rahkonen <at> mmmtike.fi> writes:
> > True, a way to improve things might be to specify -co PREDICTOR=2. Should
> > apply to both LZW and DEFLATE.
> > This is one of the filter that might be used by PNG, except that PNG has
different
> > filters, so it will eventually beat TIFF deflate.
> Not a bad suggestion.
> Original 424 MB
> DEFLATE without predictor 380 MB
> DEFLATE with -co predictor=2 280 MB
One more test with LZW
Without predictor 474 MB
With -co predictor=2 307 MB
Is there something that prevents changing the default to "predictor=2" from
the current default value "1"?
-Jukka Rahkonen-
