[gdal-dev] Identity affine handling in GDALCreateGenImgProjTransformer2
Even Rouault
even.rouault at spatialys.com
Mon Sep 1 08:56:40 PDT 2014
Selon Sandro Santilli <strk at keybit.net>:
> > > Uhm, locally I get a segfault when running the testsuite, with
> > > trunk untouched (autotest$ python run_all.py)
> > They should run. If you svn updated a previous working copy, try make clean
> > make
> There's no "clean" rule under autotest/
Yes, I meant in the lib, not autotest.
> I did make a fresh rebuild in gdal/ dir.
And still crashing ? Where does it crash ?
> > > Do travis run all tests ?
> > "All" : I guess hardly nobody has ever built GDAL with all drivers
> configured,
> > but most yes.
> The testsuite seems fine with the change:
> https://travis-ci.org/OSGeo/gdal/builds/34106679
> --strk;
> > > I've filed a pull request to trigger
> > > a travis build there: https://github.com/OSGeo/gdal/pull/40
http://www.spatialys.com
