[gdal-dev] Identity affine handling in GDALCreateGenImgProjTransformer2
Sandro Santilli
strk at keybit.net
Mon Sep 1 08:09:25 PDT 2014
On Mon, Sep 01, 2014 at 05:00:24PM +0200, Even Rouault wrote:
> Selon Sandro Santilli <strk at keybit.net>:
> > Uhm, locally I get a segfault when running the testsuite, with
> > trunk untouched (autotest$ python run_all.py)
> They should run. If you svn updated a previous working copy, try make clean &&
> make
There's no "clean" rule under autotest/
I did make a fresh rebuild in gdal/ dir.
> > Do travis run all tests ?
> "All" : I guess hardly nobody has ever built GDAL with all drivers configured,
> but most yes.
The testsuite seems fine with the change:
https://travis-ci.org/OSGeo/gdal/builds/34106679
--strk;
> > I've filed a pull request to trigger
> > a travis build there: https://github.com/OSGeo/gdal/pull/40
