[gdal-dev] GDAL 1.11 and EPSG:3857
maw269
maw269 at gmail.com
Tue Sep 2 14:59:51 PDT 2014
Using GDAL 1.11
When I use the gdalwarp command:
gdalwarp -s_srs ESRI::EPG94.prj -t_srs epsg:*900913 *EPG94.ecw 900913.tif
I get legitimate gdalinfo with datum and spheroid defined.
Driver: GTiff/GeoTIFF
Files: 900913.tif
Size is 76318, 41566
Coordinate System is:
PROJCS["Google Maps Global Mercator",
GEOGCS["WGS 84",
*DATUM["WGS_1984",*
*SPHEROID["WGS 84",6378137,298.257223563,*
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (13363025.433129203000000,-2674166.549594078200000)
Pixel Size = (0.163524580961778,-0.163524580961778)
Metadata:
AREA_OR_POINT=Area
COLORSPACE=RGB
COMPRESSION_RATE_TARGET=9
VERSION=2
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (13363025.433,-2674166.550) (120d 2'31.56"E, 23d29'18.24"S)
Lower Left (13363025.433,-2680963.612) (120d 2'31.56"E, 23d32'40.94"S)
Upper Right (13375505.302,-2674166.550) (120d 9'15.15"E, 23d29'18.24"S)
Lower Right (13375505.302,-2680963.612) (120d 9'15.15"E, 23d32'40.94"S)
Center (13369265.368,-2677565.081) (120d 5'53.36"E, 23d30'59.60"S)
Band 1 Block=76318x1 Type=Byte, ColorInterp=Red
Description = Red
Band 2 Block=76318x1 Type=Byte, ColorInterp=Green
Description = Green
Band 3 Block=76318x1 Type=Byte, ColorInterp=Blue
Description = Blue
gdalwarp -s_srs ESRI::EPG94.prj -t_srs epsg:*3857 *EPG94.ecw 3857.tif
I get illegitimate gdalinfo with datum and spheroid unknown and
unretrievable:
Files: 3857.tif
LOCAL_CS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
*DATUM["unknown",*
*SPHEROID["unretrievable - using*
UNIT["degree",0.0174532925199433]],
AUTHORITY["EPSG","3857"],
UNIT["metre",1]]
Metadata:
AREA_OR_POINT=Area
COLORSPACE=RGB
VERSION=2
INTERLEAVE=PIXEL
Corner Coordinates:
Description = Red
Description = Green
Description = Blue
This messes up my geoserver image pyramid when I try to use it.
It seems epsg:900913 works but epsg:3857 does not.
The thing is, gdalwarp to 3857 worked in gdal 1.10
Thanks,
Matt
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-1-11-and-EPSG-3857-tp5159753.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
