[gdal-dev] ERROR: Points of LinearRing do not form a closed linestring
Luca Delucchi
lucadeluge at gmail.com
Wed Sep 3 04:55:11 PDT 2014
On 2 September 2014 16:06, Even Rouault <even.rouault at spatialys.com> wrote:
> Just as suggested by the error message, your polygon is not closed. You must
> repeat the first point as last point to form a valid polygon.
The problem was in the input json file, I created it with only four
point, and I forgot the fifth (the repeated one).
In this case ogrinfo should return an error? I was also able to see it
correctly in QGIS...
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
