[gdal-dev] unable to write a shapefile using ogr
Beau Taylor
purelyamethyst at gmail.com
Thu Sep 11 21:49:26 PDT 2014
I tried to insert the 'feature name', but could not. Can some one correct
it?
field_defn = ogr.FieldDefn("Name", ogr.OFTString)
field_defn.SetWidth(32)
feature.SetField("Name", name)
On Thu, Sep 11, 2014 at 6:33 AM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
wrote:
> Kyle Shannon <kyle <at> pobox.com> writes:
> > Style is usually dictated by the application. You can set them in the
> > app, or for some formats/drivers you can use the OGR style API:
> > http://gdal.org/ogr_feature_style.html
> > AFAIK, shapefiles do not support styles
> As you said, style is dictated by application. If you create an "OGR_STYLE"
> column into shapefile and populate it with OGR feature style strings some
> programs can utilize them. I know that Mapserver can do it as well as GDAL
> when it writes PDF files.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140912/0171fdd3/attachment.html>
