[gdal-dev] unable to write a shapefile using ogr
Even Rouault even.rouault at spatialys.com
Fri Sep 12 01:18:28 PDT 2014
Selon Beau Taylor <purelyamethyst at gmail.com>:
> I tried to insert the 'feature name', but could not. Can some one correct
> it?
> field_defn = ogr.FieldDefn("Name", ogr.OFTString)
> field_defn.SetWidth(32)
There's a missing call to :
layer.CreateField(field_defn)
and you should make sure to instanciate the feature *after* having added the
field to the layer, otherwise crash is likely.
> feature.SetField("Name", name)
> On Thu, Sep 11, 2014 at 6:33 AM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
> wrote:
> > Kyle Shannon <kyle <at> pobox.com> writes:
> > > Style is usually dictated by the application.  You can set them in the
> > > app, or for some formats/drivers you can use the OGR style API:
> > > http://gdal.org/ogr_feature_style.html
> > > AFAIK, shapefiles do not support styles
> > As you said, style is dictated by application. If you create an "OGR_STYLE"
> > column into shapefile and populate it with OGR feature style strings some
> > programs can utilize them. I know that Mapserver can do it as well as GDAL
> > when it writes PDF files.
> > -Jukka Rahkonen-
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
