[gdal-dev] Building GDAL against custom libtiff
Even Rouault even.rouault at spatialys.com
Wed Sep 17 03:01:16 PDT 2014
Juan,
It might be possible that one of the other third-party library that GDAL links
to already links against your system library. Try a as minimal as possible
GDAL build first to see if my hypothesis is right.
Another thing to check is after configure to open GDALmake.opt. If there are
occurrences of "-L/usr/lib ", remove them, and run make.
Even
Le mercredi 17 septembre 2014 11:36:49, Juan Pedro Pérez Alcántara a écrit :
> Hi,
> I'm having from quiet some time now an issue when building GDAL against an
> external TIFF library. For sure is a very silly thing but I'm missing
> something important nonetheless. So long, I ended up always compiling with
> --with-libtiff=internal and have a perfectly functional installation, but
> I'm just curious about this.
> The things goes as follows: I installed tiff-4.0.3.tar.gz from osgeo.org,
> then I try to configure the GDAL build with --with-libtiff=/usr/local/,
> where I installed the libtiff, and it compiles. But somehow, when executing
> gdalinfo against a TIFF, I get the following:
> Warning 1: libtiff version mismatch : You're linking against libtiff 3.X,
> but GDAL has been compiled against libtiff >= 4.0.0
> And when I ldd gdalinfo, I get:
>  libtiff.so.4 => /usr/lib/i386-linux-gnu/libtiff.so.4 (0xb6482000)
>  libtiff.so.5 => /usr/local/lib/libtiff.so.5 (0xb640e000)
> and I'm at a loss, it seems that is trying to link to the system library
> instead the custom installed. Any insight on this will be most welcomed.
> Many thanks in advance.
> Chief Science Officer
> jp.alcantara at geographica.gs
> +34 670 786 422
> Avda. de Grecia 8
> 41012 Sevilla, Spain
> T  +34 954 701 157
> F  +34  955 110 441
> *www.geographica.gs <http://www.geographica.gs>*
http://www.spatialys.com
