[gdal-dev] ogr2ogr sqldump?
Vladan Divljak ghostility at gmail.com
Sat Sep 27 08:45:13 PDT 2014
I want migrate data between PostGIS enabled Postgres database and SQL
Server spatial database. ogr2ogr seems like easiest possible way, but there
is a catch with this ticket: http://trac.osgeo.org/gdal/ticket/5239
I tried it nonetheless, but as expected Postgres tables with UTF-8 strings
show garbage in SQL Server.
I don't see any switch in org2ogr to be able to dump sql queries that
ogr2ogr executes in migration process. Is there any? That way I can
search/replace to get correct sql queries for the task.
Thanks,
Vladan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140927/2ed1415d/attachment.html>
