[gdal-dev] ogr2ogr sqldump?
Kyle Shannon
kyle at pobox.com
Sat Sep 27 10:48:37 PDT 2014
Vladan,
On Sat, Sep 27, 2014 at 9:45 AM, Vladan Divljak <ghostility at gmail.com> wrote:
> Hi,
> I want migrate data between PostGIS enabled Postgres database and SQL Server
> spatial database. ogr2ogr seems like easiest possible way, but there is a
> catch with this ticket: http://trac.osgeo.org/gdal/ticket/5239
> I tried it nonetheless, but as expected Postgres tables with UTF-8 strings
> show garbage in SQL Server.
> I don't see any switch in org2ogr to be able to dump sql queries that
> ogr2ogr executes in migration process. Is there any? That way I can
> search/replace to get correct sql queries for the task.
Have you looked at the pgdump driver for ogr:
http://gdal.org/drv_pgdump.html
It may suit your needs.
> Thanks,
> Vladan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Kyle
