[gdal-dev] ogr2ogr sqldump?
Tamas Szekeres
szekerest at gmail.com
Sat Sep 27 14:39:01 PDT 2014
This is something that can be fixed by binding the UTF8 strings as unicode
when passing to the ODBC driver. Going to provide a fix for this issue in
the MSSQL driver soon.
Best regards,
Tamas
2014-09-27 17:45 GMT+02:00 Vladan Divljak <ghostility at gmail.com>:
> Hi,
> I want migrate data between PostGIS enabled Postgres database and SQL
> Server spatial database. ogr2ogr seems like easiest possible way, but there
> is a catch with this ticket: http://trac.osgeo.org/gdal/ticket/5239
> I tried it nonetheless, but as expected Postgres tables with UTF-8 strings
> show garbage in SQL Server.
> I don't see any switch in org2ogr to be able to dump sql queries that
> ogr2ogr executes in migration process. Is there any? That way I can
> search/replace to get correct sql queries for the task.
> Thanks,
> Vladan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140927/19718911/attachment.html>
