[gdal-dev] ogr2ogr sqldump?
Tamas Szekeres
szekerest at gmail.com
Sun Sep 28 03:29:08 PDT 2014
Committed a fix in trunk (http://trac.osgeo.org/gdal/changeset/27746)
Best regards,
Tamas
2014-09-27 23:39 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> This is something that can be fixed by binding the UTF8 strings as unicode
> when passing to the ODBC driver. Going to provide a fix for this issue in
> the MSSQL driver soon.
> Best regards,
> Tamas
> 2014-09-27 17:45 GMT+02:00 Vladan Divljak <ghostility at gmail.com>:
>> Hi,
>> I want migrate data between PostGIS enabled Postgres database and SQL
>> Server spatial database. ogr2ogr seems like easiest possible way, but there
>> is a catch with this ticket: http://trac.osgeo.org/gdal/ticket/5239
>> I tried it nonetheless, but as expected Postgres tables with UTF-8
>> strings show garbage in SQL Server.
>> I don't see any switch in org2ogr to be able to dump sql queries that
>> ogr2ogr executes in migration process. Is there any? That way I can
>> search/replace to get correct sql queries for the task.
>> Thanks,
>> Vladan
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140928/9cc1a977/attachment-0001.html>
