[gdal-dev] ogr2ogr sqldump?
Tamas Szekeres szekerest at gmail.com
Mon Sep 29 05:10:25 PDT 2014
Yes, some test data would be helpful to reproduce this problem.
Thanks,
Tamas
2014-09-29 14:07 GMT+02:00 Vladan Divljak <ghostility at gmail.com>:
> Tamas,
> I tested r27766 briefly. Unlike stable release this dev version fails to
> migrate most of the tables that otherwise migrate fine with stable. Those
> that do migrate fine have correct encoding. Thanks.
> This could mean that there is some patch between stable and dev that
> causes a problem, and maybe it's not related to your patch.
> Those tables that do not migrate crash ogr2ogr. Before ogr2ogr crashes
> here are some logs:
> ERROR 1: INSERT command for new feature failed. [Microsoft][ODBC SQL
> Server Driver][SQL Server]Unclosed quotation mark after the character
> string 'POLYGON ((...'
> OGR2OGR: Unable to write feature 28082 into layer test.
> I don't know if that's related to the crash or it is just debug info.
> If you wish me to test some data I'm willing to cooperate.
> Regards,
> Vladan
> On Sun, Sep 28, 2014 at 6:16 PM, Vladan Divljak <ghostility at gmail.com>
> wrote:
>> On Sun, Sep 28, 2014 at 12:29 PM, Tamas Szekeres wrote:
>>> Committed a fix in trunk (http://trac.osgeo.org/gdal/changeset/27746)
>> Tamas,
>> Thank you for the quick fix. Very nice gesture.
>> I'm excited to try it as soon as available on
>> http://www.gisinternals.com/sdk
>> Will report back
>> Regards,
>> Vladan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140929/0271a0b2/attachment.html>
