[gdal-dev] Writing interior rings is not working
Heiko Thiel
heiko.thiel at hpi.de
Fri Apr 10 08:37:38 PDT 2015
Hello,
I currently trying to save Polygons in a ShapeFile with Gdal 1.11.2. It
works so far - except interior rings are not stored. Anyone any idea?
My Code:
#include <ogrsf_frmts.h>
#include <iostream>
#include <vector>
#include <cassert>
int main(int argc, char *argv[])
OGRRegisterAll();
OGRSFDriver *poDriver =
OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName("ESRI Shapefile");
if (poDriver == nullptr)
std::cout << "ESRI Shapefile driver not available." << std::endl;
return 0;
OGRDataSource *poDS = poDriver->CreateDataSource("gdaltest.shp",
nullptr);
if (poDS == nullptr)
std::cout << "Creation of output file failed." << std::endl;
return 0;
OGRLayer *poLayer = poDS->CreateLayer("polygons", nullptr,
wkbPolygon, nullptr);
if (poLayer == nullptr)
std::cout << "Layer creation failed." << std::endl;
OGRDataSource::DestroyDataSource(poDS);
return 0;
//write 1 polygon with with 1 exterior and 2 exterior rings
OGRFeature *poFeature =
OGRFeature::CreateFeature(poLayer->GetLayerDefn());
OGRPolygon polygon;
auto outerRing = std::vector<std::pair<int, int>>({ { 0, 0 }, { 0,
5 }, { 5, 5 }, { 5, 0 } });
OGRLinearRing ring;
for (auto &p : outerRing)
OGRPoint pt;
pt.setX(p.first);
pt.setY(p.second);
ring.addPoint(&pt);
polygon.addRing(&ring);
auto innerRingBase = std::vector<std::pair<int, int>>({ { 1, 1 }, {
1, 2 }, { 2, 2 }, { 2, 1 } });
//auto innerRingBase = std::vector<std::pair<int, int>>({ { 2, 1 },
{ 2, 2 }, { 1, 2 }, { 1, 1 } }); //reverse order don't work too
const int innerRingOffsetX = 2;
for (int i = 0; i < 2; i++)
OGRLinearRing innerRing;
for (auto &p : innerRingBase)
OGRPoint pt;
pt.setX(p.first + i*innerRingOffsetX);
pt.setY(p.second);
ring.addPoint(&pt);
polygon.addRing(&innerRing);
assert(polygon.getNumInteriorRings() == 2); //this don't throw, so
gdal detected interior rings
polygon.closeRings();
poFeature->SetGeometry(&polygon);
if (poLayer->CreateFeature(poFeature) != OGRERR_NONE)
std::cout << "Failed to create feature in shapefile." << std::endl;
OGRFeature::DestroyFeature(poFeature);
return 0;
Regards
