[gdal-dev] gdal_translate truncates nodata_value < -4.21358e-09
Even Rouault
even.rouault at spatialys.com
Fri Apr 10 13:49:06 PDT 2015
Siebe,
I've created the following test file:
$ cat test.asc
ncols 2
nrows 2
xllcorner 0
yllcorner 0
cellsize 1
NODATA_value -3.40282346638529E+38
-3.40282346638529E+38 0
1 2
$ gdalinfo test.asc -stats
Driver: AAIGrid/Arc/Info ASCII Grid
Files: test.asc
Size is 2, 2
Coordinate System is `'
Origin = (0.000000000000000,2.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Corner Coordinates:
Upper Left ( 0.0000000, 2.0000000)
Lower Left ( 0.0000000, 0.0000000)
Upper Right ( 2.0000000, 2.0000000)
Lower Right ( 2.0000000, 0.0000000)
Center ( 1.0000000, 1.0000000)
Band 1 Block=2x1 Type=Float32, ColorInterp=Undefined
Minimum=0.000, Maximum=2.000, Mean=1.000, StdDev=0.816
NoData Value=-3.4028234663852886e+38
Metadata:
STATISTICS_MAXIMUM=2
STATISTICS_MEAN=1
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=0.81649658092773
==> So the nodata value is well taken into account, and the pixel at position
(0,0) that is at nodata is well excluded from the stats.
Then converting it again to AAIGRID :
$ gdal_translate test.asc test2.asc -of aaigrid
$ cat test2.asc
ncols 2
nrows 2
xllcorner 0.000000000000
yllcorner 0.000000000000
cellsize 1.000000000000
NODATA_value -3.4028234663852885981e+38
-3.4028234663852885981e+38 0
1 2
(slightly different last figures, but as we output 20 and than only 15 or 16 are
really significant, that doesn't matter)
Confirmed by computing again statistics :
$ gdalinfo -stats test2.asc
Files: test2.asc
Size is 2, 2
Corner Coordinates:
Min=0.000 Max=2.000
Metadata:
STATISTICS_MEAN=1
Then converting to HFA :
$ gdal_translate test2.asc test2.img -of hfa
And again checking statistics :
$ gdalinfo test2.img -stats
Driver: HFA/Erdas Imagine Images (.img)
Files: test2.img
Size is 2, 2
Corner Coordinates:
Band 1 Block=64x64 Type=Float32, ColorInterp=Undefined
Description = Layer_1
Metadata:
LAYER_TYPE=athematic
STATISTICS_MEAN=1
So I'm not sure how to reproduce your problem.
Even
http://www.spatialys.com
