[gdal-dev] create GeospatialPDF using Python
Luca Delucchi
lucadeluge at gmail.com
Mon Apr 20 00:51:57 PDT 2015
On 17 April 2015 at 15:12, Even Rouault <even.rouault at spatialys.com> wrote:
> I can open it. See below. If you tried different ./configure options between
> builds, make sure to make clean before rebuilding, otherwise files might not
> get recompiled
Ok, rebuild from scratch it works.
Last question, I have GeospatialPDF with the right style for vector
and I tried to join it with geotiff, the output has right geometries
position but wrong color, could be this a bug?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
