[gdal-dev] Formats that support RAT's?
Ivan Lucena
lucena_ivan at hotmail.com
Tue Apr 28 14:04:56 PDT 2015
> From: even.rouault at spatialys.com
> To: gdal-dev at lists.osgeo.org
> Date: Tue, 28 Apr 2015 22:58:16 +0200
> Subject: Re: [gdal-dev] Formats that support RAT's?
> Le mardi 28 avril 2015 22:49:23, jramm a écrit :
> > It seems GDAL will always let you create a Raster Attribute Table (in
> > memory) but may fail when writing to disk depending on whether the format
> > supports it?
> A lot of format that relies on the PAM(Persistant Auxiliary Metadata)Dataset base class will serialize it in a .aux.xml file.
> > I can't seem to find any information anywhere on what formats support
> > RAT's? Is there a list I can refer to ??
> From the result of "grep -r SetDefaultRAT frmts/ ", the answer is Idrisi, GeoRaster, KEA and HFA.
The RST format (Idrisi driver) doesn't really support RAT. That was included in the driver because, software ***, could not read GDAL Category Names at that time, but it could read read it as RAT. Don't ask me why.
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/Formats-that-support-RAT-s-tp5203365.h
> > tml Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150428/8f31263f/attachment.html>
