[gdal-dev] Problems with WMS minidriver
Andreas Oxenstierna ao at t-kartor.se
Wed Apr 29 00:56:10 PDT 2015
Federico,
You got a login error:
0ERROR 1: GDALWMS: The server returned exception: [5][Gatekeeper]
Gatekeeper logon avvist av BAAT.
Your request is thus rejected ("avvist" in Norwegian) by the Norwegian national login service BAAT.
Either you always need to supply a valid login, or there is a limit on the number of tile requests from a
IP number per day for non-authorized requests. This limit was rather low, at least 5 years ago.
Best Regards
Andreas
> Hi guys, i'm trying to get a wmts layer but i'm getting an error. I think
> that i'm doing something wrong but i don't what's wrong.
> URL: http://opencache.statkart.no/gatekeeper/gk/gk.open_wmts
> GetCapabilities:
> http://opencache.statkart.no/gatekeeper/gk/gk.open_wmts?service=WMTS&request=GetCapabilities
> Tile from WMTS:
> http://opencache.statkart.no/gatekeeper/gk/gk.open_wmts?SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&LAYER=matrikkel_bakgrunn&STYLE=default&FORMAT=image/png&TILEMATRIXSET=EPSG:4326&TILEMATRIX=EPSG:4326:1&TILEROW=0&TILECOL=2
> *My XML file*
> <GDAL_WMS>
> 	<Service name="TMS">
> 		<Version>1.0.0</Version>
> <ServerUrl>http://opencache.statkart.no/gatekeeper/gk/gk.open_wmts/lyrs=matrikkel_bakgrunn&x=${x}&y=${y}&z=${z}</ServerUrl>
> 	</Service>
> 	<DataWindow>
> 		<UpperLeftX>180.0</UpperLeftX>
> 		<UpperLeftY>90.0</UpperLeftY>
> 		<LowerRightX>-180.0</LowerRightX>
> 		<LowerRightY>-90.0</LowerRightY>
> 		<TileLevel>20</TileLevel>
> 		<TileCountX>1</TileCountX>
> 		<TileCountY>1</TileCountY>
> 		<YOrigin>top</YOrigin>
> 	</DataWindow>
> 	<Projection>EPSG:4326</Projection>
> 	<BlockSizeX>256</BlockSizeX>
> 	<BlockSizeY>256</BlockSizeY>
> 	<BandsCount>3</BandsCount>
> 	<MaxConnections>5</MaxConnections>
> 	<Cache />
> </GDAL_WMS>
> *gdalinfo from the file*
> Driver: WMS/OGC Web Map Service
> Files: none associated
> Size is 268435456, 268435456
> Coordinate System is:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.257223563,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0,
>          AUTHORITY["EPSG","8901"]],
>      UNIT["degree",0.0174532925199433,
>          AUTHORITY["EPSG","9122"]],
>      AUTHORITY["EPSG","4326"]]
> Origin = (180.000000000000000,90.000000000000000)
> Pixel Size = (-0.000001341104507,-0.000000670552254)
> Image Structure Metadata:
>    INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  ( 180.0000000,  90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
> Lower Left  ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
> Upper Right (-180.0000000,  90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
> Lower Right (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
> Center      (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>    Overviews: 134217728x134217728, 67108864x67108864, 33554432x33554432,
> 16777216x16777216, 8388608x8388608, 4194304x4194304, 2097152x2097152,
> 1048576x1048576, 524288x524288, 262144x262144, 131072x131072, 65536x65536,
> 32768x32768, 16384x16384, 8192x8192, 4096x4096, 2048x2048, 1024x1024,
> 512x512, 256x256
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
> 512x512, 256x256
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
> 512x512, 256x256
> *gdal_translate from the file*
> C:\>gdal_translate -of JPEG -outsize 256 256 a.xml a.jpeg
> Input file size is 268435456, 268435456
> ERROR 1: a.xml, band 1: IReadBlock failed at X offset 0, Y offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-WMS-minidriver-tp5203330.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150429/471586a3/attachment-0001.html>
