[gdal-dev] WMTS support in GDAL
Jeremy Palmer
JPalmer at linz.govt.nz
Wed Apr 29 17:33:47 PDT 2015
Is it now possible to read WMTS sources using the GDAL WMS driver? The case looking at is using a service such as https://data.linz.govt.nz/set/2-nz-aerial-imagery/webservices/ and which has custom tile matrix specification and a RESTFul Tile access API.
Cheers,
Jeremy Palmer
Data Services Group Manager
Location Information - Data Services
E jpalmer at linz.govt.nz | DDI 04 498 3537 | M 027 2747 862
Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
W www.linz.govt.nz<http://www.linz.govt.nz/> | www.landonline.govt.nz<http://www.landonline.govt.nz/> | data.linz.govt.nz<http://www.data.linz.govt.nz/>
[cid:image001.png at 01D08341.873BCAE0]
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150430/4dc4c59f/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150430/4dc4c59f/attachment-0001.png>
