[gdal-dev] WMTS support in GDAL
Even Rouault
even.rouault at spatialys.com
Thu Apr 30 00:55:11 PDT 2015
Le jeudi 30 avril 2015 02:33:47, Jeremy Palmer a écrit :
> Is it now possible to read WMTS sources using the GDAL WMS driver? The case
> looking at is using a service such as
> https://data.linz.govt.nz/set/2-nz-aerial-imagery/webservices/ and which
> has custom tile matrix specification and a RESTFul Tile access API.
Hi Jeremy,
There is no dedicated WMTS driver (or WMS "mini-driver"). However in
particular - but common- cases, for example when the tiling scheme is the
GoogleMapsCompatible one, and more generally when all resolution levels have
the same origin point, and their resolution differ by a factor of 2, you can
use a definition of the WMS TMS mini-driver.
In your case, you can put the following content in a .xml file and it will work
(adapted from http://www.gdal.org/frmt_wms_openstreetmap_tms.xml).
<GDAL_WMS>
<Service name="TMS">
<ServerUrl>http://tiles-a.data-
cdn.linz.govt.nz/services;key=327224a02cc4453ba183441bbb6267aa/tiles/v4/set=2/EPSG:3857/${z}/${x}/${y}.png</ServerUrl>
</Service>
<DataWindow>
<UpperLeftX>-20037508.34</UpperLeftX>
<UpperLeftY>20037508.34</UpperLeftY>
<LowerRightX>20037508.34</LowerRightX>
<LowerRightY>-20037508.34</LowerRightY>
<TileLevel>20</TileLevel> <!-- limited to 20, instead of 21 since GDAL
block array would require much too memory -->
<TileCountX>1</TileCountX>
<TileCountY>1</TileCountY>
<YOrigin>top</YOrigin>
</DataWindow>
<Projection>EPSG:3857</Projection>
<BlockSizeX>256</BlockSizeX>
<BlockSizeY>256</BlockSizeY>
<BandsCount>4</BandsCount>
<Cache />
</GDAL_WMS>
A proper driver would infer that from the capabilities, and possibly deal with
the annoying cases I mentionned (the fact that overviews in WMTS may have not
the same origin point is the most annoying one)
Even
> Cheers,
> Jeremy Palmer
> Data Services Group Manager
> Location Information - Data Services
> E jpalmer at linz.govt.nz | DDI 04 498 3537 | M 027 2747 862
> Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
> PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
> W www.linz.govt.nz<http://www.linz.govt.nz/> |
> www.landonline.govt.nz<http://www.landonline.govt.nz/> |
> data.linz.govt.nz<http://www.data.linz.govt.nz/>
> [cid:image001.png at 01D08341.873BCAE0]
> ________________________________
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you
> must not peruse, use, disseminate, distribute or copy this message. If you
> have received this message in error, please notify us immediately (Phone
> 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
http://www.spatialys.com
